A lot of White smoke coming out of exhaust!!!!
So i just changed my DV, and i took what you guys said and i used a little oil to get it in. When i started it up a lot of smoke was coming out of the exhaust. after turning it off and letting it run for while the smoke died down alittle bit. Could have some oil got in? thats the only thing that could have happened. But if some did it would only be probobly a drop, would it go away, would the oil eventually burn up.. is it bad for the car?!?!?
Just went outside.. its not the oil!! I put the OEM one back in and it wasnt smoking at all!!! drove it alil and it was good.. put the forge 007 in and it started smoking up really bad! Do i have it in right>?? wats the problems??????
Hmm, defnately wierd. Should be pretty obvious how to install it, I dont know what would happen if you screwed the install up... but yes, oil is blue... coolant or water is white. Leave the forge on for a bit, and see what happens.
