Why does my hood sit lower than my side panels?
Old May 28, 2011 | 06:57 PM
rawdney88's Avatar
Default Why does my hood sit lower than my side panels?
my hood is the only thing low on my car...how sad right? about 2 mm low. anyone know how come? i checked the bolts and connectors for the hood and they arent loose or detatched. any suggestions or input would be appreciated
**note the only reason it bothers me is because the hood isn't flush with the one piece headlights i installed.
Old May 28, 2011 | 07:11 PM
Audisaurus's Avatar
Did you do a swap? if so thats the line where the 2 piece would split... im assuming its jus ta tad lower with the two piece and considerign tis not meant for a 2 piece then thats why. Or the rubber stops from your hood are missing
Old May 28, 2011 | 07:16 PM
NickBroderick's Avatar
Who knows, but don't worry about it. I think mine is off by a 1 mm also, it's an old *** car, don't sweat the little things.
Old May 28, 2011 | 07:22 PM
ObnoxiousDrunk's Avatar
^This.....if you start getting picky about how lines match up, you end up like a buddy of mine......with a new car. But that deal with swapping out the 2 piece for the 1 piece headlights sounds like it could be the issue.
now you are going to make me see if mine is the same way.
Old May 28, 2011 | 08:23 PM
rawdney88's Avatar
never done a swap. but, from what i could...there are foam pieces missing that should lift the hood up. im guessing. so im gonna cut some old coolant tubing from my old honda and stick it under there to see if it makes a difference. i know it's not a BIG issue but everytime i walk by i look at it...it drives me nuts
Old May 28, 2011 | 08:29 PM
ilackav8's Avatar
the headlights could be throwing it off. try adjusting the bump stops thats probably the issue
Old May 28, 2011 | 09:32 PM
Mike-2ptzero's Avatar
There are 2 rubber stoppers on either side of the hood that allow you to adjust where the hood sits when it is closed. Just turn it so there is more of it and that will raise the hood slightly to match the fender line.
Old May 29, 2011 | 02:15 AM
rawdney88's Avatar
you know i was looking at this. and they have little arrows on them. so i match the arrows to where they are tight and at its lowest point. so i guess i should just loosen them up to make them stick out more. ty for that.. i completely disregarded that for some stupid reason
Old May 29, 2011 | 06:55 AM
foxracing4500's Avatar
deleted
Old May 29, 2011 | 01:43 PM
rawdney88's Avatar
Originally Posted by foxracing4500
cant help with the post topic but your headlights are nice! Also how is your front bumper that clean? like no rock niks or scratches
haha thanks man. i know exactly why. i drive f***ing slow and here in SoCal we don't have too much rubble on the road...we have garbage, furniture, tons of rusty nails, and sand on our roads.
Bklynrx7
May 16, 2010 03:56 PM
jiggleo
Sep 29, 2009 10:13 PM
thrasher
Sep 18, 2008 02:50 PM
mlo517
May 7, 2005 05:40 PM
fiver5
Mar 31, 2005 02:25 AM
