Why a ebay K04 is off limits.
Old Nov 8, 2010 | 02:28 AM
HulkB5's Avatar
Default Why a ebay K04 is off limits.
So im still not considering buying one from everyones opinion of how eBay can't be trusted.
But the thing is if you look at this
http://cgi.ebay.com/ebaymotors/KO4-0...ht_1805wt_1165
It has a 6 month warranty, i i purchased it i could bring it to horsepower freaks and they would test if for me...
If its bad then wouldn't the warranty cover it?
i know this may seem stupid, but i am new to cars in general and i like to learn as much as possible about them.
Old Nov 8, 2010 | 02:33 AM
Andrew149's Avatar
i see your point i guess its so cheap you can buy like 4 of them but the main point is they last for a few weeks to a few months somtimes a year depends if your pounding on your turbo 24/7 like most of us are so pretty much why we say no is the bearing inside the turbo goes to **** and bam no more turbo than your buying another turbo so the rule of thumb
buy nice or pay twice
Old Nov 8, 2010 | 02:36 AM
HulkB5's Avatar
Yeah and when you get into the range that high its not to far off from a elim kit...
Old Nov 8, 2010 | 02:48 AM
Andrew149's Avatar
heres the real thing cheapest i found a real ko4 http://cgi.ebay.com/ebaymotors/ws/eB...d=300407777036
Old Nov 8, 2010 | 03:17 AM
zerokiller698's Avatar
edit: to original post
Its not a true KKK K04. That one is made of cheep metal.
Old Nov 8, 2010 | 05:37 AM
kriptonik's Avatar
There was a thread on a different forum about the knock-off K04.
It has received mixed reviews but for the price and if you're doing the work your self, I'd say it's worth to try.
Old Nov 8, 2010 | 07:32 AM
ImTheDevil's Avatar
...unless it frags the compressor wheel when it fails and blows metal shards into your engine cylinders...
Old Nov 8, 2010 | 11:44 AM
Msnickbroderick's Avatar
Actual WIZARD
Back in my honda days, my friend bought a ebay t3/t4, and it was fun on 10lbs, till the wastegate failed, and it managed to peg the boost gauge, which in turn (we assume) wrecked the bearing, causing turbine to housing contact and literally shattering the wheel. This happened over about 5 seconds
Never go ebay unless you like gambling with your pistons
http://cgi.ebay.com/ebaymotors/T3-T0...ht_4686wt_1165
But hey its only $105
Old Nov 8, 2010 | 12:40 PM
kriptonik's Avatar
Well, they say the biggest problem is the small wastegate (which is actually smaller than the stock K03) that causes it to overboost. I don't think the turbo will fall apart (as they'd get sued) but it just won't last as long as the original Borg Warner.
Honestly, I'm curious when it comes to it. People have said so many different things about it. I also consider the fact that aftemarket ball bearing turbos are so much better than the original ones.
Old Nov 8, 2010 | 04:12 PM
BaseDrifter's Avatar
Site Moderator/B5 Tech Guru
Exactly what I was thinking.
