Wierd Beeping Sound! HeLp!
Old Aug 17, 2010 | 12:21 PM
Pedja's Avatar
Default Wierd Beeping Sound! HeLp!
so i was driving around today after watching some racing movie and i decided to give my car a little more gas then usual, popped the sucka into 3rd and gunned her till the redline, car sounded as if it choked a bit and all the sudden this beeping noise appeared!
when i drive it now it seems to beep in low rpm's (up to 4.5) and then once i hit 5 rpms and drive like that it stops the beeping, then when i go down again it continues the beeping, drove around with the beep for about 10 mins after the redlinage so i don't think anything busted? or maybe it did
if anyone had a similar situation and can help me out by letting me know what happened and what to do that would be great!
thanks for taking the time!
Old Aug 17, 2010 | 12:52 PM
CCA4's Avatar
How many beeps? Any lights to go with them?
Old Aug 17, 2010 | 01:02 PM
Pedja's Avatar
nope, no lights with it and its kind of 4 then stops i think, im going to go drive it around the block and acually count. brb
Old Aug 17, 2010 | 01:04 PM
FASTER's Avatar
Tech Slut
Usually beeping comes with an oil light or a brake light.
Old Aug 17, 2010 | 01:09 PM
CCA4's Avatar
I was gonna say, that sounds like an oil light beep. I have a slow leak (actually three slow leaks ) and if i corner hard near my oil change interval when the motor's down about a quart, I get a blinky oil light and the beeps you're talking about. Maybe your oil light is just burned out?
Old Aug 17, 2010 | 01:18 PM
Pedja's Avatar
yea see now i drove it for 10 mins and no beeping, i dont know, but i do know i have a small power steering pump leak, too lazy to change the pump since i did it once already, but i dont know, i was driving like an idiot once the beep occurred, sharp turning very high revs and stuff like that.
Old Aug 17, 2010 | 03:12 PM
Desert Fox's Avatar
Could be low oil pressure if the baffles aren't working, as you go around corners. Don't know how they would fail though.
Old Aug 17, 2010 | 06:42 PM
Jc61990's Avatar
coolant will beep too
Old Aug 17, 2010 | 07:34 PM
morpheous's Avatar
coolant and window washer fluid will beep
Old Aug 17, 2010 | 07:40 PM
Pedja's Avatar
okay thanks alot, both my coolant and washer fluid were a little low, i added both so now it doesnt beep or anything, thanks alot guys!
