will my b5 pass inspection if the pixle is messed up?
Old Jan 2, 2011 | 05:10 PM
sb301's Avatar
Default will my b5 pass inspection if the pixle is messed up?
idk if you guys no what im talking about, but in the middle part of the dash (were it usualy tells u how many miles befor u run out of gas) its messed up... idk how to explain it but it looks scratched out? lol my question is will it pass maryland state inspection.
Old Jan 2, 2011 | 05:49 PM
bradtyler02's Avatar
I'm not familiar with Maryland's inspection laws, but it should pass no problem. It doesn't interfere with safety or emissions.
Old Jan 2, 2011 | 06:04 PM
CCA4's Avatar
It will pass just fine. In cars equipped with that center LCD screen, all the lights that are considered during inspection (air bag, brake, and CEL) are located in the open space on the tach/speedo.
Besides, you could just turn off the LCD screen and the guy doing the inspection would have no idea
Old Jan 2, 2011 | 06:11 PM
sb301's Avatar
thanx!!!!!!!! also can u guys help me with one more question please! lol
to the left of the center pixle screen there is number there? i am woundering if these are the "codes" people are always talking about i know i know ...noob -_-
Old Jan 2, 2011 | 06:16 PM
CCA4's Avatar
the codes people always talk about are pulled from the ECU by an OBDII scanner, they don't just pop up on that screen.
There's another screen to the left of the center screen that displays the date and time, is that what you're talking about?
Old Jan 2, 2011 | 06:32 PM
sb301's Avatar
its at the bottom of the rpm? it saidd 1.14 and other **** but maybe i just need to reset the date?
Old Jan 3, 2011 | 06:57 AM
CCA4's Avatar
Yep thats the time/date you're talkin about. There's a little post right next to that window that sticks out the front of the gauge cluster. Pull on it to select HH:MM:SS, AM/PM, MM-DD-YYYY, respectively. Then turn the post clockwise until it clicks to increment the hour, counterclockwise to decrement the hour. Same goes for minutes, seconds, days, months, years. Finally, pull the post once more to turn the date display on or off.
FWIW, that won't have any effect on whether or not you pass inspection either
Old Jan 13, 2011 | 06:23 AM
sb301's Avatar
thanks cca2
millenia
Dec 23, 2019 11:47 AM
FixOrRepairDaily
Dec 21, 2017 04:17 PM
cmarin
Jan 21, 2010 05:50 PM
cmarin
Jan 21, 2010 02:11 PM
Dudek12
Jun 2, 2006 11:07 AM
