Will these fit?
Old Feb 23, 2009 | 09:58 AM
Beast06's Avatar
Default Will these fit?
http://www.velocitymotoring.com/links/wheels_v714.htm
I really want to get those rims and was wondering if they would fit without rubbing with a 1.5" drop on a 96 a4 ?
Old Feb 23, 2009 | 03:08 PM
kriptonik's Avatar
I have seen those wheels in real life. I believe VMR brought couple cars with those wheels to a show.
Anyway, which size specifically are you going for?
Old Feb 23, 2009 | 04:39 PM
Beast06's Avatar
19x8.0's, just not sure what offset I would need. I don't think I would be able to lower the car at all with those wheels.
Old Feb 23, 2009 | 08:32 PM
kriptonik's Avatar
http://www.1010tires.com/WheelOffsetCalculator.asp
You can check it out your self. I believe stock offset is 45mm (I could be wrong). Also I believe as long as you stay 10mm from the stock offset, you should be fine.
I believe those wheels with fit with no problem since they are 8 inches wide. I also believe you can even lower your car with those.
I ran a set of 19's with the car lowered and they were pretty wide (I ran staggered with 9.5 in the rear) and it ran fine. Basically, if you want to lower the car, you play the game with stretching the tires, fender rolling, and even adjusting the camber/toe.
Old Feb 23, 2009 | 09:42 PM
hiwords's Avatar
you can lower the car with those wheels but i would recommend rolling fenders and not getting tires wider than 235. those are very nice though. if you're not rich and you DD the car, i wouldn't touch the camber/toe. i recommend you get the 19x8 +38 mm ones.
Old Feb 23, 2009 | 10:06 PM
Beast06's Avatar
How exactly do you roll the fender?
Old Feb 24, 2009 | 12:39 AM
brrman's Avatar
I would second this.
Rolling fender means pushng the inner lip of the fender up and inwards to prevent the tire from rubbing it. Typically done with a rolling pin and a hairdryer. You can rent a tool from PureMS.com I think.
Old Feb 24, 2009 | 12:46 AM
kriptonik's Avatar
Second that. You should be able to rent tool from them. You only need to do the front fenders as the rears are already rolled in (at least for 2001 but I believe all B5's are the same).
You can also try calling couple body shops or even your local tint shops and ask if they're willing to do it. (Some shops don't do it due to liability issue).
I would also have to agree with hiwords. I personally don't recommend playing with camber/toe if you DD the car due to uneven wear of tires or even safety. Good luck!
Old Feb 24, 2009 | 09:43 AM
klum00's Avatar
i'd go for it. i'm running 19x9.5 in the rear right now with no rub. you can make it fit.
Old Feb 24, 2009 | 09:45 AM
Beast06's Avatar
Thumbs up
I know what fender rolling is, I was just wondering more of how to do it. I looked on youtube and there are few demo videos on there. Thanks for the help
