Windows not working or the sunroof
Old Mar 28, 2013 | 03:52 PM
sadik666's Avatar
ImTheDevil is right, your issue is not the vacuum pump but it is your central locking system or central convenience system ( depend on the model ) and the vacuum pump is part of it... I had the exact same issue before ( no power windows and roof ) but locks work fine .. I had to change the central locking system ... there is a pump and a electronic module in it ... sadly, the only way to find out is to test with a another central locking system ( easy to do but you have to buy the replacement part fist, or borrow one to a friend with the same car ) ... good luck
Old Mar 28, 2013 | 04:09 PM
86f250xlt's Avatar
My 96 a4 sunroof works and my passenger side rear window works but the rest don't move any ideas?... I know passenger side front switch is bad but I was told it all worked fine a window regulator was changed and now it seems most of the windows don't work
Old Jul 20, 2015 | 02:41 PM
Solomatthew's Avatar
Originally Posted by matthewa4
I have a 98 A4 that the windows and the sunroof stopped working on but the I still can roll the windows up and down using the key in the door. I believe that the window module has gone bad but I can't find it to save mylife. I was told that it was behind the drivers side kick panel or under the dash do it is not. Does anyone have any clue where it is on my car or do you think it is something else wrong with the window system?
Have figured it out yet my 99 a4 is doing the same
dawns
May 19, 2015 05:09 PM
Dan.petro
Feb 10, 2014 03:34 PM
Brians01A6
Feb 23, 2011 05:27 PM
esseboo
Apr 19, 2010 01:37 PM
Townshend2372
Oct 27, 2004 05:20 PM
