Wiring kit question.
Old Oct 24, 2009 | 01:14 PM
NickBroderick's Avatar
Default Wiring kit question.
I'm installing my HID wiring conversion and my stock wires have two that are yellow and white. On the conversion wires it says tan and white and yellow and white. Does it matter which ones I connect with the stock wires both being yellow and white?
Old Oct 24, 2009 | 01:28 PM
CCA4's Avatar
Yes. There won't be two wires that serve the same purpose, that doesn't make sense. Do you have a voltmeter? Using that, you can test the wires to see which is which.
Edit: One was probably tan at one time in it's life, but 13 years in your engine bay will do that.
Old Oct 24, 2009 | 01:55 PM
They were the exact same color. I don't have a meter. Do you know what would happen if I did it trial by error?
Old Oct 24, 2009 | 02:22 PM
CCA4's Avatar
Well I accidentally swapped two wires when i did mine, so when i turned on my headlights, the passenger's side high beam would come on lol. not a big deal, you'll get it eventually one way or another.
Old Oct 25, 2009 | 01:49 PM
Yeah I figured that's what would happen. I got it right the first time . Thanks for your help!
EvoTillIDie1
Mar 5, 2014 10:42 PM
freeloader700
Mar 29, 2012 06:04 PM
12inchsubs
May 16, 2011 01:39 PM
borninrussia3
Jun 24, 2008 09:25 PM
taz42zero
Nov 22, 2007 02:08 PM
