Wiring nightmare.
Old Dec 2, 2019 | 03:12 PM
Ghostrider 67's Avatar
Default Wiring nightmare.
I have turned my attention to the wiring nightmare that awaits me. I have to marry up 1967 Dodge Charger hidden headlights, a 1970 440 BB V8, 1966 Ford Thunderbird tail lights and 1967 Dodge Coronet engine harness and remaining lights. to a 2001 Audi dash and ECU. I know.
So, what I think I know so far is that the speedo works off of a pulse from the trans. The A727 trans doesn't do that, but, they make an adapter that does so that's done. The harnesses for the doors are good, seats are good, so what I need help with is the rest.
So here's the questions I have at the moment;
Splicing cut wires, okay to lap join ends and solder with heat shrink to protect? Or what
Do ALL of the wires operate via a pulse signal to the ECU? If not, which do?
If all are pulse type, can the sending units be fitted to the 440?
There are some things that I clearly will have no need to hook up. What must I do with these wires in order to not have code issues/ECU faults?
The motor is carbureted so there are no sensors, no throttle body no MAF etc.
Will the ECU work without connecting every last thing it thinks it should be getting readings from?
That will do for starters and I'm sure many more will crop up as I go. TIA. Ghost.
Old Apr 19, 2020 | 04:37 PM
Originally Posted by Hellen34
Oh, it sounds really bad... Haven't you thought about buying a new car instead of it? Like one of my friends had the same situation and he decided to buy a new one. He is thinking about ford explorer but he's not sure yet. Probably you or someone else here can say something about it? It would be great
hey there. Did you miss the part where I'm building a 1967 Dodge Coronet muscle car resto mod? It's all part of the build and is fun and interesting for me. I have new cars. One is a Ford Escape Titanium. This a project and it will get done. Thanks for your reply. Randy
1967 Dodge Coronet 500 rear face with 1966 Ford Thunderbird tail lights & 1970 Road Runner rear bumper, all fabricated to work together.
1967 Coronet with Audi A-6 dash and door treatments w/ console and all gauges and sound system, A/C, Heat etc.
Right door finished fabrication.
Old May 11, 2020 | 09:09 PM
John_E's Avatar
Holy cr@p! I gave up on my 1996 A4 Quattro after it fried its power window circuit. I do have the 1996-2001 Bentley manual with full wiring diagrams, if you need any of that info.
Touge
Apr 21, 2009 02:35 AM
Karl
Dec 21, 2007 10:45 AM
k4rr
Oct 5, 2007 12:32 PM
bhj0887
Mar 22, 2006 03:58 PM
