Zero boost issue
Old Aug 18, 2013 | 04:50 PM
mk4cam's Avatar
Default Zero boost issue
Im having a 0 boost issue on my aeb 1.8t. Under vacuum it runs perfect but the second i try to get into boost it shoots up to zero. The exhaust sounds boggy like its being choked and there is a whistle or whine noise which comes from under the hood. This will only happen under a heavy load. I replaced my k03 thinking the turbo was blown or a wastegate issue. The turbo i installed is a newly rebuilt k03 with 0 miles. I have also installed a n75 valve that i know works and still the same. I replaced the apr DV with a brand new forge 007 that i have and still the same.
2 week ago i did get code p0422 for the cat, but i cleared it to see if it would reappear and hasn't. Would a clogged cat or junk 02 sensor cause only high load problems? So to sum it up i have no CEL, runs great under vacuum, and sounds choked under WOT or high load. Thanks for the help guys
Old Aug 18, 2013 | 06:25 PM
george1546's Avatar
A clogged cat will cause the car to feel choked when putting the foot down, I would say it would be worse of at high load as more exhaust gases are running through, not sure however if this relates to zero boost.
hotswaps
Aug 8, 2013 05:50 PM
hotswaps
May 27, 2013 07:02 PM
Bradw
Dec 14, 2011 02:16 PM
njtrackstar
Feb 19, 2009 01:23 AM
kerNol
Nov 28, 2008 10:13 PM
