'02 A4 1.8T - thermostate diagnostic help
Old Nov 8, 2008 | 12:53 PM
pmkcolorado's Avatar
Default '02 A4 1.8T - thermostate diagnostic help
temp guage stays at C for long period of time, then rises to 1/4 and heater works. I suspect thermostat, anything else I need to check before replacing...Replaced temp sensor, problem still exists;
thanks,
note that I changed out timing belt 5 K miles ago...
Old Nov 8, 2008 | 02:11 PM
AutoUnionFan's Avatar
Should have done the theromstat when you did the t/b. The ECT sensor could be casuing the gauge to misbehave but I dont know how to check that without buying a new one.
Old Nov 8, 2008 | 10:21 PM
wolfdog's Avatar
Yea, the ECT (engine coolant temparture) sensor is cheap (<$10 from dealership) and is the first thing to do. I assume that's what you did when you say temp sensor.
As for the thermostat, it would have been easier to do with the TB but it's not necessary. I was going to do it when I did my TB 5k miles ago too but read that it's a fairly easy change and people recommended it be done when it goes rather than preemptively due to it's high cost (not just the t-stat but the housing as well).
I can't think of anything else for you to check before doing this, sorry.
Old Nov 8, 2008 | 10:26 PM
The one I got for my b5 from the St(d)ealer was about $25
Old Nov 21, 2008 | 06:21 PM
shane.trammell's Avatar
the 02 thermostat is no where near the timing belt so it really doesnt help to do it with the TB. the thermostat is below the throttle body and kind of behind the alternator. I just replaced mine about 2 months ago. There was no option for me to just replace the housing or sensor or anything, it was all one part. I got mine from aboveallmotorwerks.com and it was like $77 for the oem part.
Old Nov 21, 2008 | 10:51 PM
auditech79's Avatar
What? You don't have an 02 1.8T then. Any 1.8T engine after 2001 has the thermostat behind the timing belt, the AEB and ATW block has the seperate thermostat by the bottom of the motor on the driver side.
Old Nov 22, 2008 | 12:05 AM
heres a link to the part i ordered and installed. http://www.aboveallmotorwerks.com/Pr...121111K_S.aspx
my car is def an 02 b6! bought it from a dealer as a cpo
Old Nov 22, 2008 | 11:04 AM
I have the Bentley manual but can't find the info for either the sensor light or the thermostat...
Old Nov 22, 2008 | 11:21 AM
it would help if I could spell "thermostat" when searching...Shane is right as the thermostat is behind the alternator, not part of the timing belt replacement proceedure, and is not servicable. You need to replace the entire housing...
Old Nov 23, 2008 | 02:13 PM
auditech79's Avatar
Oh yes, you're right i aplogize. Its the TT that has it the way im thinking of. There are so many different versions
