03 A4 3.0l AVK engine throttle surge
Old Feb 18, 2009 | 11:20 AM
motorcars's Avatar
Post 03 A4 3.0l AVK engine throttle surge
I've got an 03 A4 AVK engine in the shop that intermittently has a throttle surge, and stalling. Got a Vag-com scanner and has no faultcodes present. Installed a newly rebuilt throttle body and still has same condition. Wondering if anyone has run into this before,Thanks
Carlos
Old Feb 18, 2009 | 11:35 AM
shane.trammell's Avatar
Sounds like vacuum problems.
Old Jan 25, 2011 | 04:39 AM
Paz's Avatar
Paz
Carlos
Hi,
Did you find a resolution to the throttle surge / stall problem?
Cheers.
Old Jan 25, 2011 | 07:16 PM
auditech79's Avatar
Originally Posted by Paz
Hi,
Cheers.
Don't think the OP is going to respond to a two year old thread, its best to make a new thread. However let me save you the trouble, you most likely have a vacuum leak, and a vag com scan tool can verify that www.ross-tech.com
Old Jan 26, 2011 | 04:14 AM
Paz's Avatar
Paz
Was worth a punt.
Have VCDS and there are no DTC's.
MAF cleaned. Gonna have a garage clean the Throttle Body & check IAT Sensor, MAP Sensor & Vacuum Hose. Access is too tight for me on the V6.
Best course of action IYO?
Old Jan 26, 2011 | 01:14 PM
motorcars's Avatar
I do remember this car ,it's been a while. I ended up finding water in the fuel system, installed some dry gas and filled the tank with good high octane. drove car for a day and it was fixed!! hope this helps
carlos
Old Jan 26, 2011 | 09:06 PM
auditech79's Avatar
^^^I stand corrected, i have never seen someone with less than 10 posts reply to a thread more than a year old, im shocked.....
However water in the fuel system is very rare, i would first check all your vacuum lines first, then check throttle body for carbon build up, clean the intake with seafoam, then after all that drain the fuel system and change out the gas.
Old Jan 27, 2011 | 04:29 AM
Paz's Avatar
Paz
Big Thanks to you both; better than any advise I received from the dealership, unsurpisingly.
A busy weekend ensuses....
Old Jan 27, 2011 | 11:33 PM
motorcars's Avatar
If you don't have any lean codes or any other faults in engine control module then I think your wasting your time with the vacum leaks or throttle service. These engines are really sensitive to vacum leaks and throttle adaption. I think it's with trying some octane boost and good gas before you spend the money that's not going to fix it. Also I do remember reading a tsb for misfiring and idle problem. Audi says a reflash of engine control is the fix. Hope this helps.
Carlos
Old Feb 27, 2012 | 09:03 PM
spinningpedals's Avatar
subscribing
dstehle
Apr 22, 2024 01:37 PM
mikehinnenkamp
Apr 12, 2012 09:12 PM
Anastasia Sarantos Taskin
Sep 24, 2010 12:27 AM
nicegollum
Nov 22, 2007 09:19 PM
steffos
Dec 23, 2004 02:17 AM
