04 A4 1.8T coils
Old Apr 16, 2008 | 08:46 AM
mcburton's Avatar
Default 04 A4 1.8T coils
Hello there,
I am a new owner of an A4 1.8T and I noticed in the vehicles records that it had the coil replaced for cylinders 2, 3, and 4 and it seems ot be aquirk with these cars.My question is, how do you know when they go bad? Is it a complete failure (i.e., will you have a cylinder misfiring) or is performance just reduced? Also, will it throw a code if a coil goes bad?
Thanks,
Old Apr 16, 2008 | 08:54 AM
jzmuda's Avatar
Default RE: 04 A4 1.8T coils
It just happened to me last week, the car will start missfiring or shaking really bad and then the check engine light will blink and if you get the codes read it will tell you what cylinder is missfiring, you will loose lots of performance and if you don't get it fixed you are risking cloggng your catalyticconverter after a while.
Old Apr 16, 2008 | 09:09 AM
mcburton's Avatar
Thank you jzmuda. What do you use to read your codes? Do you have a code reader/diagnostic tool you recommend?
Thanks,
Old Apr 16, 2008 | 10:23 AM
jamesfreeman86's Avatar
Ya... just go to AUTOZONE and they have a code reader you can use. But like MCBURTON said, you will notice a bad coil when you start to misfire and lose a bit of power
Old Apr 16, 2008 | 04:25 PM
jzmuda's Avatar
I have a VagCom and a SnapOn reader but VagCom is the way to go.
Old Apr 16, 2008 | 04:54 PM
mcburton's Avatar
Thanks Jerry!
MarkKlockgether
Jun 19, 2013 03:42 PM
frankiefrank555
Jan 17, 2010 08:25 PM
Leeer73
Feb 9, 2009 04:33 AM
thecheda
Dec 17, 2007 01:38 PM
turbo kraut
Sep 23, 2007 09:53 AM
