04 Needs Turbo??
I'm going to look at an 04 that the guys said needs a turbo, I can bring my VagCom to scan it, will that tell me for sure it needs a turbo and not a piston etc. He said it runs fine but smokes. Any ideas? If it needs a turbo is it worth $5000, it has 125,000 miles,in nice shape.
Won't a Vag Com show a turbo code, or a misfire cylinder, that would steer me in the right direction , no? It's smoking so a bad turbo smokes and so does a bad piston or rings, I'm just trying to see if someone can help me differentiate between the 2.
Unfortunately no a scan will not tell you or give you bad pistons or turbo codes. If you really want the car, pay to have it taken into an independent shop to have a cylinder leak down test and compression test done. If it checks out on those, then its highly likely the turbo seals are bad. You'll be able to know right away if the turbo is whining and louder than normal. What color smoke (black, white, blue?) these are also ways to sort of diagnose what is going on.
Clos2010
Sep 3, 2013 08:15 PM
03a418tnate
Aug 10, 2010 08:07 PM
SupraSkylineSTI
Apr 2, 2010 10:46 AM
mr V8
18
Jun 23, 2006 03:21 AM
DickM
12
Mar 21, 2006 05:15 AM
