1.9 TDI B6 Jerking then eventually limp mode
Old Apr 19, 2017 | 12:42 AM
naudeap's Avatar
Default 1.9 TDI B6 Jerking then eventually limp mode
Good day all
This is a long read so get a cuppa java first.
I have 2004 1.9.TDI. It has 350Km on the clock and has been serviced religiously by the dealer till 330K. I then started getting a jerk / flat spot during winter when the car temp was between cold and running temp. I could actually predict when it would start with the jerking.
It was however a slight jerk and would go away when I accelerate or drive above 120km.
It would eventually go away when it reached running temp. It sometimes couldn't even get to running temp in winter.
I then took it to a "German car specialist" in who serviced the car and also change a sensor that "manages" the temp / choke mode??? and also the thermostat.
When I got it back it ran perfectly again, till about 10 000km after service.
Then it started jerking when it reached running temp.
Once again I could almost predict when it would start. It also started off with a slight jerk every now and then, but after about 10-15KM I would not feel it again.
Now its almost all the time.
Then last month it go so bad the ESP light came on and the car went into limp mode.
I also almost went into limp mode.
However when I got home I switched off and back on again and it was "fine" till about 200m from home and it started all over again and eventually back into limp mode.
The engine mngt light was now also on.
So I went to google... It seemed I wasn't alone, but I couldn't really find any obvious cause, however most spoke about the MAF and EGR valve.
ah... ok so I disconnected the MAF, drove for 400m and the car started to jerk and eventually went into limp mode.
Went back home. Switched off the car then back on again. went driving for over 10 KM's slight jerk every now and then.
Went back home and plugged the MAF back in, just to make double sure, engine Mngt light is still on though, went driving for over 10KM's again slight jerk every now and then, same as when I had it unplugged and it didn't go into limp mode.
Then it started doing it while cold until normal running temp, then it was fine.
It basically got worse. I had to let the car get to normal temp (90 degrees) first before I could drive. Then it would "behave" for most of the time, sometimes jerking at 3000rpm.
Being a diesel you don't always get to 3000rpm unless you need to accelerate across traffic lights etc. I don't do this anymore, as I don't know what will happen.
5000Km later and now it stays in limp mode, no matter what I do.
Cold or hot...
I have to travel 120Km to work daily, I cannot afford this to happen.
I also don't know what damage I'm doing while in limp mode.
A colleague of mine did the diagnostic test. The diagnostic says intermittent electric fault on injector on cylinder 1.
Now I'm stumped.
I'm not a mechanic. I have a hammer and a screw driver somewhere.
I need a Audi TDI specialist, who dreams about TDI's, for online help.
pps. I changed the fuel filter (and seals) about 500KM ago when it start jerking at normal running temp.
The fuel pump sounds ok.
I bought this car new in Dec 2004 and I have had absolutely no problems, it has been extremely good to me.
In fact my average diesel consumption since 2004 overall has been 5.4l/100KM.
Please help. I cannot afford to buy a "new" car now.
I can also be pm on naudeap@gmail.com.
Makhana
Oct 29, 2014 01:26 PM
mikedisco
Aug 28, 2014 03:46 PM
wobblewoo
May 9, 2012 09:37 AM
hjheap1
May 8, 2011 03:26 PM
