2002 A4 3.0 Cam Phaser/ Sensor Issue Help Please
Old Jul 18, 2015 | 09:05 PM
seanclearwater's Avatar
Default 2002 A4 3.0 Cam Phaser/ Sensor Issue Help Please
I've got a 2002 A4 3.0 that has become quite a millstone for me. I bought the car for what was in hind site a too good to be true situation. The owner told me that it needed a camshaft position sensor (which I verified by pulling the code before I bought it). It is running rough, throwing a multiple misfire code, and a P0345 Camshaft Position Sensor A Bank 2 code.
Replaced the sensor, no change.
Decided it was likely mistimed. Retimed 2 times with extreme care following audi procedure to the T using cam locks and crank lock pin. No change.
I have checked and all the cam sensors are putting out signal at the sensor.
I have checked compression and found that Bank 1 is all at 150psi on the nose, Bank 2 is all at 180psi on the nose. Also, bank 2 plugs look/smell rich when pulled. Interesting.
Because of this I suspect that there is an issue with the cam phaser or phasors, or their related components. I saw some sludge while the valve covers were off and suspect that something is sludged up and not allowing the phaser to move.
I suppose perhaps the signal from the Bank 2 sensors could be failing to make it to the ECM too.
Anybody got insight into how to track down which is the problem?
If I were to throw down a wishlist of diagnostic help it would be:
1) How do I check to see if the which phasers are working or not working. If they are not working, how can I track down what components are causing the problem.
2)How can I test to see if the signal is getting to the ECM.
I have tried two VAG COM diagnostic softwares from EBAY and have not had any success in getting them to work (Both were obviously pirated/ hacked together with garbled russian hacker instructions that resulted in nothing but errors). If anyone knows of a workable VAG COM scanner that would not be a huge investment.
Thanks, frankly the car has been a thorn in my side.
Yankeefan
Jun 13, 2013 07:28 PM
careercadaver
Aug 19, 2010 08:40 AM
soldierboy15
Apr 21, 2009 04:42 PM
petedonlan80
Aug 15, 2008 10:18 PM
modset
Jan 19, 2008 11:28 PM
