2003 Audi A4 2.0 fsi starting problems PLEASE HELP!!!
So this is going to be a long story but I'm hoping one of you can help!
Last week I broke down, car just lost power and came to a stop.
Had a previous fault of crankshaft sensor, so put it down to being that. Both the crank and cam sensors changed to which the car still wouldn't start. We plugged it into VAG-COM and it could get into everything but the ECU. We then found loose wires under the steering wheel, so reconnected them and the car started! We had it running for 24 hours before the ESP light came on so we pulled over and turned the car off, to now be back to the original problem, the engine is turning but will not start. We have replaced a relay think it was 219 and have checked all other wires. We are now getting Fault codes P0445 and P0037 which are EVAP Emission Control System Purge Valve C Short and HO2S Bank 1 Sensor 2 Heater Circuit Low. These faults all lead back to the ECM, would replacing this solve all the problems or will it be a new ECU?? Or has anyone else got any ideas or suggestions please help!!!
skateboy918
Oct 15, 2013 11:58 AM
