2003 audi a4 3.0 Manual Upper Oil pan replacement
The engine will need to be supported from up top , drain oil , remove lower pan , lock carrier in service position , unbolt a/c compressor , remove oil cooler housing , remove air pump , lower front of subframe , remove alternator , remove starter & after that it is a cake walk.
I finally got around to doing it. The oil pump was kind of a pain. That has to come down too.
