2003 audi a4 3.0 Manual Upper Oil pan replacement
Old Feb 28, 2012 | 02:26 PM
omar3143's Avatar
Default 2003 audi a4 3.0 Manual Upper Oil pan replacement
has anybody done this before? Anythin i should be worried about when replacing it? Maybe some instructions out there?
Old Feb 28, 2012 | 02:58 PM
M5S5's Avatar
Tech Certified
The engine will need to be supported from up top , drain oil , remove lower pan , lock carrier in service position , unbolt a/c compressor , remove oil cooler housing , remove air pump , lower front of subframe , remove alternator , remove starter & after that it is a cake walk.
Old Feb 28, 2012 | 04:35 PM
omar3143's Avatar
Sounds like a lot more work than I thought it would be. I guess maybe I won't attempt to do it myself.
Old Apr 22, 2012 | 06:04 PM
omar3143's Avatar
I finally got around to doing it. The oil pump was kind of a pain. That has to come down too.
Old Apr 23, 2012 | 09:33 AM
M5S5's Avatar
Tech Certified
Let us know how you make out!
Old Apr 23, 2012 | 03:38 PM
omar3143's Avatar
Got it done. got the car to turn on. Now I'm looking for some parts for the front end.
plim
Apr 4, 2014 05:13 PM
fusnowtiger
Jul 17, 2013 01:18 AM
Lastb0isct
Feb 12, 2009 12:49 PM
JOnJOn
Feb 8, 2008 11:15 PM
kadrap
Jun 1, 2006 12:37 PM
