2003 Audi A4 Alarm Problem How to disconnect
I have an 03 Audi 3.0 with an alarm problem. The alarm when I lock the doors and set the alarm will beep once and then keep beeping for about 120 seconds. Sometimes it works fine, sometimes it doesn’t. Sometimes the alarm beep is so quite you cant even hear it. Pushing the buttons again to lock or unlock the car does nothing, putting the key in the lock does nothing, starting the car does nothing when the beeps keep going off. You just have to wait until the beeping quits. I reset the alarm by putting the key in the door and turned it back and forth twice. I read on another forum that the alarm siren itself has a battery in it. Its VERY hard to change. I’m looking for a quick DIY on this. Can I just pull a fuse? Use a VAG to turn the alarm off all together? Can I just unplug it back by the siren? The car itself has a pretty new battery. Thanks
Hey, I seem to have had similar alarm problems. Sometimes when I lock doors with the remote, the alarm keeps sounding. I can lock and unlock a few times - sometimes the alarm shuts off.
Did you just disconnect the wire to the alarm? Do you know anything about replacing the battery in the alarm?
Thanks for your help!
I have a issue with my alarm also, It was set off for the first time the other day and It is so quiet the beeping is not loud at all!! is it supposed to sound the car horn when it goes off? or is my alarm battery low so its not loud anymore?? what kind of battery is it that the alarm uses???
thanks for the help
thanks for the help
Any pictures or updates on this alarm issue? My alarm works just fine except I can barely hear it. I see you mention a battery that needs replacement. A part number would be appreciated. Thanks all!
yea its located on the right side under the cubby box. hmm not sure on part number. i would imagine u search google something would come up. Let me google that for you
I have the same issue on a 2003 B6. Corrosion on the board is beyond repair. I have ordered a new unit from the stealership. My question is this... I have removed the unit and the alarm is still going off - the lights are still flashing all night - on and off. Is this what usually happens? Do I have an additional problem
Is there any way of just bypassing the unit and not having any alarm or chirp on lock?
Many thanks,
Many thanks,
