2004 A4 1.8T Rough Idle
Old Mar 5, 2011 | 02:55 PM
katsat1's Avatar
Default 2004 A4 1.8T Rough Idle
Just changed oil dipstick in new to me A4. Rough idle at start-up. This hose/broken check valve found. Anyone know what it is? Where it connects? The hose terminates on right (driver) side of engine bay below power steering add reservoir. Thanks for help Shane and others. Scott
Attached Thumbnails 2004 A4 1.8T Rough Idle-mvc-074s.jpg   2004 A4 1.8T Rough Idle-mvc-073s.jpg
Old Mar 5, 2011 | 02:58 PM
katsat1's Avatar
Default An additional pic...
Additional photo of location of hose/broken check valve.
Old Mar 5, 2011 | 06:20 PM
shane.trammell's Avatar
Doesnt look like the check valve is broken, you just need to find what it is disconnected from.
Old Mar 5, 2011 | 07:32 PM
katsat1's Avatar
I looked hard and couldn't find the spot. If anyone recocnizes this connection/line appreciate the help. Scott
Old Mar 7, 2011 | 10:22 AM
Ok it looks like that should hook to a T fitting that is under the intake manifold, behind the throttle body. you should just have a T fitting with one open nipple
Old Mar 7, 2011 | 10:43 AM
katsat1's Avatar
I agree that would appear to be the right spot, but that joint has a piece of solid rubber with a clamp...What does this do? The line was maybe off for a while and we just disturbed it?
Old Mar 7, 2011 | 11:44 AM
Sounds like a block off for some reason. I would try to hook it back up.
Old Mar 7, 2011 | 01:48 PM
katsat1's Avatar
Got it. T was $2.30 part at local Baron supply. Appreciate your help.
Scott
jeff.welch0620
Oct 10, 2013 06:24 PM
justinclarke
Nov 25, 2010 04:03 PM
specialK4
Jul 27, 2006 03:19 PM
Railslider
Oct 27, 2005 01:57 AM
