2004 Audi A4 3.0 oil leak HELP
Old Aug 19, 2014 | 10:25 PM
winning_blue's Avatar
Default 2004 Audi A4 3.0 oil leak HELP
I recently purchased the car and noticed an oil leak. It's not a ton of oil but more than I would ever like. I checked all of the electronics/lights/switches and the car is perfect, just failed to look under the front of the car. This is my first German car that I've owned so I know maintenance will never be cheap.
What should I check for? OR
Where should I take the car to get looked over? I'm not sure if there is a better (cheaper) route than the Audi dealership.
Old Aug 19, 2014 | 10:36 PM
JF1957's Avatar
Is your car a quattro
Old Aug 19, 2014 | 10:41 PM
yeah it is a quattro
Old Aug 22, 2014 | 11:44 AM
ppgoal's Avatar
I bought a 2003 A4 3.0 MT6 for my daughter 5 years ago. Nice car. I would check the obvious -- valve cover gaskets. It also depends on where they leak is in relation to the engine - parking on some clean pavement may help you isolate. I have had leaks from my rear tranny seal and differential (in my 2.7T) at different times in it's 231k life. Engine area leaks are normally caught by the plastic under-engine cover - which is why the Germans put them on these cars. If yours it missing, then you will see the leaks that end up on the cover.
BamaAudi
Apr 20, 2014 09:23 AM
dray
Jan 16, 2014 04:28 PM
Pitbull's S4
Mar 28, 2011 11:42 PM
cudafish
Dec 28, 2010 12:36 AM
mshprojects
Aug 27, 2007 08:04 AM
