2004 Cabrio Dipped Headlight Conundrum
Old Jan 3, 2014 | 10:12 AM
mhk1058's Avatar
Default 2004 Cabrio Dipped Headlight Conundrum
Hi,
I have a 2004 B6 A4 Cabriolet 3.0. I've always thought dipped headlights were a bit dim so eventually got round to thinking it should be easy enough to put some decent bulbs in. Went to one of the main online suppliers, put in the reg etc and ordered some Ring H7.
Now, once I got the one of the headlight units off I immediately noticed that the dipped headlight unit looks like some fancy sealed unit within the main unit, the like of which I've never seen before, with no obvious means to access it or replace it. No amount of searching on the net has come up with anything other than this should be a straightforward bulb replacement.
Anyone any ideas, is this some sort of upgrade aoption when new?
BTW, I have some cheap unused Ring Xenon Ultima H7's going.... full beam are H9's!
Cheers
Old Jan 3, 2014 | 05:55 PM
pa4ul's Avatar
not sure if you are looking at the same headlights ive looked at. Once the housing is out swapping the bulb whether it be hid or halogen is very simple. you just need to remove the cap on the back of the housing that is held via the silver retainer clip. from there simply unplug the wire pull the retainer clip off the bulb and swap. Shouldnt take more then a few minutes. Also if you are running stock hids the bulb is ds1 not h7. H7 would be halogen capsules.
Old Jan 3, 2014 | 06:20 PM
mhk1058's Avatar
Thanks for the reply.. I think you are talking about this type
. Unfortunately, mine look nothing like that. No clips, just a twist fit electrical connection onto what looks like a sealed unit... maybe best if I took a picture. Will try and post something tomorrow.
Old Jan 6, 2014 | 01:17 PM
pa4ul's Avatar
yea a pic would be best. sOunds like someone threw an aftermarket kit into your car..
Old Jan 6, 2014 | 04:45 PM
ECS Tuning's Avatar
Sponsor
Definitely post a picture, it's hard to exactly know what you mean with out one for this instance.
Jason
Jrmiller
Feb 25, 2013 03:03 PM
ee99ee
Oct 25, 2010 11:10 PM
shane.trammell
Dec 15, 2009 09:53 PM
ins516a4
Dec 3, 2007 11:10 PM
sandiegocanuck
May 24, 2007 04:09 PM
