3.0 N80 Valve- Flow
Old Mar 30, 2012 | 09:39 AM
big_c's Avatar
Default 3.0 N80 Valve- Flow
I have a stored code for :
16825 - EVAP Emission Control Sys: Incorrect Flow
P0441 - 002 - Lower Limit Exceeded - Intermittent
Yesterday when filling my gas tank, it would blast out fuel also. I could only fill a small amount at a time without the pressure increasing too much to shut off the pump.
I tested my N80 valve with a multimeter- 26 ohms. When I apply 12vdc, it opens and I can blow through it, although the flow through it is fairly restricted (think blowing through a very small diameter hose)
I have sprayed air intake cleaner through it, the flow does still seem lower than it should be.
So- Is this limited flow through the valve normal? Is my N80 bad? Is the charcoal canister bad?
Old Mar 30, 2012 | 12:05 PM
budhani786's Avatar
Clean the purge valve with a ear cleaner. If black crud comes out there your problem.
elduderino200
Jul 8, 2015 03:35 PM
gabeguimaraes
May 22, 2009 04:46 PM
audiant
Dec 10, 2006 01:29 AM
siddy
Aug 19, 2005 12:01 AM
