42 Designs LED License plate lights
Old Feb 24, 2008 | 09:26 PM
gsolo's Avatar
Default 42 Designs LED License plate lights
[align=center]Hey guys. So I did a search. I'm trying to determine if these will work in my 02. I already ordered them only $12. Someone said they would work, but I want to make sure. I saw a B6 the other day with the LEDsI had to get them But I wanted to go the cheap way. Anyone try these drop ins? Any problems with them? You guys have helped me with changing 02 sensors, I figure I could get some input on this. Thanks[/align][align=center][/align][align=center]14.5v 39mm Fuse Style LEDs
[/align]
Size
39mm long x 11mm diameter
Available Colors
White
LEDs per unit
Typical Applications
VW license plate lights. These LEDs are built to handle 14.5
volts. Our standard 12v 39mm fuse style LEDs will NOT last
in VW license plate lights. These 14.5v versions are built to
handle the excess voltage and the heat.
Price
$5 per LED
Old Feb 25, 2008 | 04:09 PM
kchao2000's Avatar
Default RE: 42 Designs LED License plate lights
I had them installed for quite some time now and it worked great. It works on my '04 so should works on yours.
Old Feb 25, 2008 | 07:29 PM
gsolo's Avatar
thanks kchao
Old Feb 26, 2008 | 11:24 AM
kchao2000's Avatar
I will try to take pictures when the weather is nice. It is raining right now.
Old Apr 2, 2008 | 02:55 PM
boy412's Avatar
I just dropped them into my '03 and they seem to work fine. One concern I have is heat. The instructions from 42 Draft Designs are very VW-centric and mention that some cars require that the lamp housings be vented. They of course do not mention Audi. Anybody know if this is necessary on our cars?
A note on installation. Those little screws are soft and easy to strip. I was careful (or so I thought) and had to drill one out anyway. Have a Dremel tool handy!
It would be nice if 42 Draft Designs could put together a kit for the B6! It would take a lot of the guess work out of this process.
Cheers,
boy412
Old Apr 2, 2008 | 03:13 PM
kchao2000's Avatar
boy412,
I asked the same questionearlier regarding the heat on our cars. The answer was LED lights normally don't generate much heat and our lamp housing is not fully sealed anyway so no need to worry about that. I've installed those bulbs for a while now and they worked good so far.
Old Apr 3, 2008 | 01:17 PM
boy412's Avatar
Cool. I've been in contact with 42 Draft Designs and they are looking for more feedback from Audi users. They would like to hear what has been working for people and what hasn't.
So let them know! They seem like very nice people and i'm happy doing business with them.
Cheers,
boy412
Old Apr 3, 2008 | 03:23 PM
rummy's Avatar
Description 14.5v 39mm fuse style LEDs are used to replace VW license plate lights. These LEDs are built to handle 14.5 volts. Our standard 12v 39mm fuse style LEDs will NOT last in VW license plate lights. These 14.5v versions are built to handle the excess voltage and the heat. Available in White ONLY.
For additional fitment information and pictures of our fuse style LEDs please visit our product page: Fuse Style LEDs
We do not recommend the use of these LEDs on the following vehicles: Mk5 VWs, B6+ Audis.
did the guy their say that b6+ is ok? why would they specifically say our cars on there?
Old Apr 8, 2008 | 10:27 AM
xster's Avatar
Member
I question the same thing? I too want to go all white LED - so do they work or do they not work?
xster
Old Apr 8, 2008 | 12:10 PM
nvr_follow_a4's Avatar
I have a set of the 14.5V 39mm fuse style white from 42 designs in my B6 and haven't had any problems. I used to have them in my B5, but I kept them and installed them in my B6 about 2 months ago without any issues. They are a little longer than the oem bulbs, but still fit in the metal clips.
