A4 Avant 1.8t engine turn-over trouble...
Old Mar 20, 2010 | 09:03 PM
cdmcolorado's Avatar
Unhappy A4 Avant 1.8t engine turn-over trouble...
Hey guys,
I own a 2005 B6 A4 Avant 1.8t and am having troubles with the engine turning over. A couple of months ago my car started taking a good 10-15 seconds to turnover when holding down the brake pedal and key turned. This problem only occurs when I have not driven my car for around 2-5 hours. Any time before and after that the engine turns over as it should.... I took the car to a shop and had a full test run of the battery, alternator, cables, and starter. The results showed there was nothing wrong, but they guessed there was a faulty section of the starter I had; consequently, I replaced the starter on my car (regrettably) and it continued to have the problem. The only after market part I have put on my Audi so far is an aFe stage II CAI.
Any ideas as to why this is happening?
Thanks.
Old Mar 20, 2010 | 09:10 PM
Dan1969's Avatar
like it cranks but doesn't start or it doesn't crank at all?
Old Mar 20, 2010 | 09:48 PM
My car cranks, and will start but only after cranking for 10-15 seconds when I haven't used it for 2-5 hours...
Old Mar 20, 2010 | 10:24 PM
shane.trammell's Avatar
Has it died? Any CELs? Could be fuel, could be spark, could be engine speed sensor...
Old Mar 20, 2010 | 10:25 PM
Dan1969's Avatar
is your coolant temperature sensor.
If you don't want to replace it every month, they tend to go bad all the time, do this: open the key without cranking it for 2 to 5 seconds depending how cold it is, then close it, then crank it. It should work, if it doesn't replace the temperature sensor.
Old Mar 20, 2010 | 11:32 PM
tmic0723's Avatar
have the same problem on my 02 a4 1.8t as well. i know for a fact it's not the battery just got a new one put in when i bought the car a month ago. but the car is turning over but just one turn on...it's annoying, takes like 5-10 seconds before the car actually starts.
Old Mar 20, 2010 | 11:44 PM
ive had this problem a couple of times. the first time the dealer said it was a dirty throttle body and intake manifold. the second time it was the engine speed sensor. the engine speed sensor might give you a cel if its bad enough, but it does wear out slowly. mine went out at around 110k, and theyre pretty common.
Old Mar 21, 2010 | 12:11 AM
thanks for the quick responses guys! I will definitely check out all of those possibilities and let you know if nothing works.
Old Mar 23, 2010 | 08:27 AM
screamin demons's Avatar
Mine is dying now. Where did you get yours from?
-Tyler
Old Mar 23, 2010 | 11:47 AM
i actually got mine from the vw dealer where i work bc i get a discount. try ecstuning.
