A4 Fog light HIDs
Old Sep 19, 2008 | 12:27 PM
kezzi22's Avatar
Arrow A4 Fog light HIDs
Does anyone have a DYI guide to changing out the fog lights?
I changed my weak a$$ hologen headlights to 6000k HID's (DIY style) and realized that i should/need to change out the fog lights too. work never stops. please help if you can
Old Sep 19, 2008 | 03:07 PM
kezzi22's Avatar
I took the time to SIMPLY "take the fog light cover off the bumper" & found that there are only two screws holding them. installing them will be as easy as the headlights. I'll post pics will the kit is on. Thanks anyway.
Old Sep 19, 2008 | 04:58 PM
audiprotein's Avatar
Old Sep 20, 2008 | 02:43 AM
scskim's Avatar
that diy is kinda ****. With mostly all HID kits now you're supplied with sufficient connections. There's no need to cut wires, solder, splice, etc.
Old Sep 20, 2008 | 01:31 PM
^^^ Like u said, not with every hid kit. If you buying the one for $200 then yes, it is plug and play, if for $50-then u need some modifications.
Old Sep 22, 2008 | 09:08 AM
Porsche2AudiHappy's Avatar
I bought mine from ebay, about 68-70 or so and it was plug and play. Two screws and some creativity about where to put the balast.
Old Sep 22, 2008 | 11:12 AM
02A4Turbo's Avatar
How do you like your ebay HID's?
Old Sep 22, 2008 | 10:44 PM
scskim's Avatar
id recommend buying from VVME. i think their site is VVME.com
Old Sep 25, 2008 | 11:06 PM
02A4Turbo's Avatar
Fair enough.. were they plug and play? or did you have to do some trimming?
Old Sep 27, 2008 | 06:39 PM
scskim's Avatar
they were plug and play. I have a b6 a4 1.8t so my stock intercooler is the mini one on the drivers side. the air inlet is the drivers side fog grill so it was a tight fit with the ballast, but all my hids work so far =)
