A4 radio reception is terrible fm has become fml
Subscribe
Mar 27, 2011 | 10:51 PM
The cd player works changes disc fine the casette player works nothing wrong there the radio..... errrr has really bad signal and i dont know why id take a look at the antenna (if i knew where it is) any ideas its just the radio signal is very bad all i get is static and a few words and scraps of a song am works ok.
Reply
Mar 27, 2011 | 11:35 PM
Is it bad on both FM and AM or just FM?
Reply
Mar 28, 2011 | 06:18 PM
its the radio antenna in the rear of the car. its prone to cracking from the heat and causing interference in radio reception. Its located ontop of the rear window. The panel should pop off and the antenna runs the length of the window.
Reply
Mar 28, 2011 | 09:26 PM
Quote: its the radio antenna in the rear of the car. its prone to cracking from the heat and causing interference in radio reception. Its located ontop of the rear window. The panel should pop off and the antenna runs the length of the window.
This is what im leading at, except his terminology is wrong. The antenna doesn't crack, the antenna amplifier cracks. Its behind the center panel on the back of the headliner. It will have radio connectors going into it like this.
Once you find it, unbolt it and look for any cracks, especially if your AM radio reception is still good.
Reply
Mar 29, 2011 | 01:00 PM
hmm havent seen that one yet auditech. I was refering to this one
http://www.audizine.com/forum/showth...adio+reception
Reply
Mar 29, 2011 | 10:40 PM
^^^Yes thats what i was talking about, thats the amplifier, just didn't have a picture of it. The antenna wraps around the back window.
The pic i posted was off a TT that was in my album, i just wanted him to see what the radio wires looked like.
Reply
Mar 30, 2011 | 06:21 PM
i was actually going to ask u where that one u posted in the pic is located. cuz i had never seen it in our cars but that explains why i hadnt seen that. but u can either try to apply pressure to the crack if its visible and see if that helps or some guys will solder a wire like in the diy above.
Reply
Apr 4, 2011 | 12:22 PM
I once had really bad FM reception on my 04 A4 Cabriolet, and I discovered that it got better if I changed stations from the steering wheel control rather than the radio control. I have no idea how or why this could possibly work, but now I make a point of changing the station from the wheel on a regular basis and my fm reception is fine (my engineering side speculates that maybe the steering wheel has a better ground and it discharged some kind of static buildup in the tuning circuit or something).
Reply
Apr 5, 2011 | 06:21 PM
Quote: I once had really bad FM reception on my 04 A4 Cabriolet, and I discovered that it got better if I changed stations from the steering wheel control rather than the radio control. I have no idea how or why this could possibly work, but now I make a point of changing the station from the wheel on a regular basis and my fm reception is fine (my engineering side speculates that maybe the steering wheel has a better ground and it discharged some kind of static buildup in the tuning circuit or something).
Cabriolet is a different beast, i believe there is a TSB for laying in an entire new FM harness on your car for poor reception.
Reply
Apr 10, 2011 | 07:50 PM
Radio antena
The Radio antena is in the trunk where it closes. My radio doesnt work no reception dealer wants $900 to fix it! They say its because the trunk is used to much!!!
Reply
