ABS Lights come and go
Old Aug 31, 2017 | 01:40 PM
radar1's Avatar
Default ABS Lights come and go
03 A-4 Q. 171,000 ,replaced F. Calipers / Pads , F.ABS censors ,cleaned the R. censors ,bleed the brakes .. The lights that were on for a few days went off for 5-10 miles and BAM back on ,they stay off for a few miles and go off then BAM all back on .. I have one says BRAKES in red blinking at me and the other two lights as well ,a orange one ABS and the triangle one as well.. I thinking ABS Mod. has went bad .. The scanner picks up nothing on the brakes .. ANYBODY ...Thanks.. New deal the Air Bags light is on also .. Checked the plug looks good ???? Help...
Old Sep 7, 2017 | 04:29 PM
FlyingScooter's Avatar
Hi radar1,
Quick question: Did you try disconnecting the battery for about a minute, reconnect it and see if that cleared the issue?
I've never had this issue with my A4, but have had it numerous times with Chevy's, Oldsmobile's, and have seen it with friends Mazda's, Toyota's and BMW's. (side-note: Have never seen it with Kia, Subaru or Mercedes Benz .)
I know, sounds out there, but who really disconnects their battery when doing break work? Most don't. I learned the hard/costly way a decade or so ago.
Good luck and best wishes! I hope this helped.
-Mark
Old Sep 8, 2017 | 01:36 PM
radar1's Avatar
Default Abs not working
Yep did that ,well over night no did not work .. I have sent the ABS Mod. to the BBA -Raman shop ,got a call today they just got it for testing ,I hope its broken if so can be fixed not ,, now what ??? Thanks
Old Sep 8, 2017 | 04:29 PM
Sorry, Radar1. I was hoping it could have been that easy.
Let me know what they find.
Have a great weekend!
-Mark
Old Sep 9, 2017 | 02:55 PM
radar1's Avatar
I missed a call from the BBA-Rman. place ,the voice mail said they fixed the ABS-module witch is a good thing if not ??? What then . I replaced the pads and censers ETC.. The module being broken is good and being fixed is a very good thing can't beat the $129.95 , I was worried ,this should fix it ..
Old Sep 14, 2017 | 05:03 PM
ppgoal's Avatar
For others who read this, Module Masters does the same type of repair.
Old Sep 14, 2017 | 05:19 PM
radar1's Avatar
Default UPDATE :Brake lights on and Air bag light on
Got the ABS censor back from BBA-Remain. $129.95 and installed worked fine all brake lights off. Bad news had the 03 in deep scan looking for the air bag problem ,bad air bag seat censor .well could by/pass or find used seat .. Looking for a used drivers seat .. Thanks for the info .
Old Sep 16, 2017 | 03:54 AM
Kash713's Avatar
I had an 03 A3 and same light was coming on. Would always kick in after spinning off from a complete stop and not go away until the engine was re-started. Would you believe it was connected to the coolant temperature sensor... It costed me €10 and the issue went away!
Though my car was properly banjaxed, all electronics were funny in it!
pezster
Oct 30, 2008 11:37 PM
sidekicklxondeck
Jun 28, 2008 11:18 AM
berdov
Feb 10, 2008 12:37 PM
charlied
Feb 22, 2007 11:52 PM
