Adding/ installing aftermarket Sirius Radio to my RNS-E. DICE Aux?
Old Jun 8, 2010 | 10:00 PM
3.0L Audi A4's Avatar
Default Adding/ installing aftermarket Sirius Radio to my RNS-E. DICE Aux?
I want to add an aftermarket Sirius tuner to my 2004 Audi A4. I don't want the OEM tuner because I already have an aftermarket tuner that works in my other vehicle and my house, so when I drive my Audi, I could just plug it into the docking station and have clear satellite music.
The Sirius unit has a power plug, and antenna plug, (both installed), now- I need to get the audio to my RNS-E. The radio adapter has a lot of static in my area and wont give a clear enough signal.( New Jersey/ New York). The Audi antenna is a different kind than the US type antenna and when I try to use the FM adapter from Sirius, it doesn't directly plug in and needs conversion leads which drains the audio quality....
I have the DICE Electronics setup for my I-Pod and it has an Auxiliary input but I cannot hear any music when I plug the 3.5mm male to male adapter from the Sirius to the DICE adapter. Is there anything I could do to make the DICE adapter Aux input work?
What are my other options with this issue? Is there a way to get an Aux 3.5mm input installed in my RNS-E?
Thanks so much in advance.
Marine702
Jan 27, 2013 07:10 PM
Bmart120
B7 Models
Oct 14, 2012 02:35 PM
chodoctr
Audi Q7
Oct 14, 2012 09:52 AM
Blade69
Nov 30, 2007 10:49 PM
orta02
Jun 23, 2006 11:43 AM
