Alternator Pully Problem?
Old Apr 11, 2008 | 07:58 AM
Abbey's Avatar
Default Alternator Pully Problem?
Alternator Pully Problem [/align][hr]
My 2003 TDI 130 seems to be having a slight problem.
The groved belt that pulls on the alternator seems to be jumping causing the belt to go slightly slack when it has passed over the alternator pulley. A freind suggested the alternator pully may be seized. Are these a fixed or inertia engaging pully. Suggestions welcome.[/align]
Old Apr 11, 2008 | 09:05 AM
techbod's Avatar
Default RE: Alternator Pulley Problem?
hmmm its a fixed single serpentine belt but you might have a bad tensioner or an alignment problem with the pulleys
Old Apr 11, 2008 | 09:29 AM
Abbey's Avatar
Thanks Dave.
The pulley's seem to be in line it seems to me like a bearing breaking down/grinding in either the pulley or the alternator, its hard to tell which!This is causing the belt to almost jump over the alternator pulley.
Old Apr 11, 2008 | 09:43 AM
techbod's Avatar
remove the belt and check for movement in the pulleys ( there should be none ) apart from rotation of course
tpkg
Feb 26, 2013 06:27 AM
cumaudia4
Jul 15, 2009 12:32 AM
tbr76
Jan 3, 2007 06:56 PM
Dudek12
May 31, 2005 10:10 PM
