anyone know how to install HID lights on an A4?
Hi, I just got mya4 and I wanted to upgrade the halogen lights to HID.Does anyone have any info that could help me out? Does anyone reccomend a kit? Also, any installation instructions or pictures that you may have would be great. thanks. (I have an 05' a4)
I strongly suggest you buy HID housings (US or E-codes). If you must keep your halogen housings, just buy a kit and the install is simple. If you were in Jersey, I'd help you out.
yea my brothers friend just put mine in recently..i know for sure u have o take out ur headlight cuz theres no room to just put the bulb in without taking them out..u dont have to take the bumper off...the 2 screws for the headlight are right on top and the other 2 are hidden behind the light
ORIGINAL: akaEsCo01
I was checking out their website(vvme) and I was wondering... What do I do with the ballast? i understand that everything is plug and play but, do I have to mount the ballast somewhere? Is there a place for it in the headlight or do I have make something to mount it. What did you guys do? Thanks
The process is pretty self explanatory. You will need to drill a hole through the headlight housing case to fit the HID wiring through, other than that you're set.
As far as the ballast mounting, I used zip ties. They've worked extremely well - all you need to do is find a good place to mount them. It's not difficult, you can figure it out once you're in the process.
I'm fairly certain someone uploaded some pics of this process. I'll take a look around and see if I can find it.
