Audi A4 1.8T - New Spark Plugs & Gap
Old May 10, 2008 | 01:22 PM
starbox189's Avatar
Default Audi A4 1.8T - New Spark Plugs & Gap
I just replaced all the coil packs and spark plugs in my 2005 A4. It has 36,000 miles and the owner's manual says to replace the plugs at 35,000 miles. Theoriginal plugs were NGK PFR6Q. The auto parts store only had Champion RC10PY4 which is supposed to be an equivalent plug. I set the gap at 0.75mm (approx 0.029"). Seems to run fine.
They're labeled as "Double Platinum" like the KGK's. Sounds like advertizing hype. Would you expect to have anyproblems switching to these plugs??
Old May 10, 2008 | 05:02 PM
SrK's Avatar
SrK
Default RE: Audi A4 1.8T - New Spark Plugs & Gap
your post doesn't specify which engine you have but I thought the gap was supposed to be 32mil for a 1.8T
Old May 10, 2008 | 05:16 PM
harryd14's Avatar
well if he has the 05, he could either have a 1.8 or the 2.0 engine, so perhaps it depends on which one he has for the gap... but he did say in the title of his post 1.8t
Old May 11, 2008 | 07:10 PM
Pablo_Ottawa's Avatar
Umm guys, look at the title.. He has a 1.8T
.032 if not chipped and .028 if it's chipped
Old May 11, 2008 | 09:04 PM
cincyTT's Avatar
I'm make believe
You want to stay with copper plugs like the ngk bkr's. Like said above on the gaps and also 6's for stock and 7's for chipped
Old May 15, 2008 | 03:34 PM
cclazer's Avatar
Member
Cincy-
I just pulled a PO171 code from my car, so I was going to clean off my MAF and replace my plugs to try and correct.
NGK pulls up the PFR plugs for the 1.8t... and my cars not chipped yet so I would get the 6's,I guess my question is,are you recommending to go with the BKR's instead of the PFR's? What would I notice between the two?
Woofie
Apr 25, 2012 08:49 PM
fhormiz
Aug 22, 2011 11:05 PM
emily0918
Nov 1, 2010 05:54 PM
Jacko 84
Aug 3, 2009 01:04 PM
Isramirez21
Apr 22, 2008 04:06 PM
