Audi A4 1.8T Vibration
Subscribe
Dec 23, 2009 | 10:17 PM
I have an Audi A4 1.8T and every time I put it in (D) Drive or (R) Reverse it makes this strong vibration that I feel in the whole car. As soon as I accelerate the vibration stops and if I put the gear in (N) Neutral, it stops the vibration.
Can somebody tell me what it might be???????
Reply
Dec 23, 2009 | 11:59 PM
is it CVT? Quattro? If its just a quattro I'd scan it for codes if possible, if not, just check the air filter, spark plugs and coil packs, alos look for a vacuum leak.
Reply
Dec 25, 2009 | 05:29 PM
Quote: is it CVT? Quattro? If its just a quattro I'd scan it for codes if possible, if not, just check the air filter, spark plugs and coil packs, alos look for a vacuum leak.
Thanks man, I will check those things!!!
I hope is nothing bad!
Reply
Dec 25, 2009 | 05:31 PM
is not a quattro!
what does CVT means? (I'm from PR and I don't know much of the many abbreviations!)
Reply
Dec 25, 2009 | 08:03 PM
CVT is the Front wheel drive version of audi, is a bad transmission and it breaks often. However the symptoms you describe up there do not sound like a transmission problem. I incline towards a vaccuum leak
Reply
Dec 26, 2009 | 03:43 PM
Quote: CVT is the Front wheel drive version of audi, is a bad transmission and it breaks often. However the symptoms you describe up there do not sound like a transmission problem. I incline towards a vaccuum leak
Yeah, its a Front Wheel Drive audi, its a new one tho. I bought this car 8 months a go and it had the transmission changed before I bought it because the first owner of the car broke it. When they first changed the transmission, the new "used" transmission had 15k miles. Not much for a 2003!
I will definitely check if it is a vacuum leak.
It might not be the transmission because I don't feel the vibration on the steering wheel at all.
Reply
Dec 28, 2009 | 12:43 PM
vibration or studder? Check for cracks in vac lines and your check valves in the lines that tend to deteriate (bad spelling) over time.
Reply
Aug 7, 2010 | 10:00 AM
could it be the transmission mount?
Reply
Feb 17, 2012 | 03:27 PM
Audi Vibration
I have the same problem as you explained. Did you fixed the problem in your car. I have a 1999 car.
Reply
Feb 17, 2012 | 04:42 PM
motor/trans mount
Reply
