Audi a4 b6 1.9 tdi 96 kw 2003 - hums at a certain engine RPM
Old Jan 12, 2025 | 11:38 AM
ciki022's Avatar
Default Audi a4 b6 1.9 tdi 96 kw 2003 - hums at a certain engine RPM
Hallo,
I've had the car for a few years, and recently it started making an unpleasant humming sound, only at a certain engine RPM, for example in 3rd or 4th gear under medium throttle. Nothing shakes, just that humming sound, which stops immediately when you step on the throttle. The car was taken to a mechanic, and the cause was not discovered (the engine runs fine, all the engine mounts were checked, the exhaust was not wobbling or getting caught somewhere). The right engine mount was replaced 2 years ago, and the left one with the sensor 3 months ago, the engine mount on the transmission is good, there is no rattling when you step on the throttle. It is mentioned that the floating flywheel can also be a problem, it is good, it doesn't shake at idle, it doesn't vibrate when starting and stopping. If you have any ideas, I would be very grateful.
Screedman
Sep 1, 2012 04:34 PM
KajunAudillac
Oct 11, 2008 03:25 AM
markyb
May 4, 2008 02:44 AM
chosos
Apr 7, 2007 01:32 PM
Jayo
Jun 25, 2005 10:48 PM
