Battery Drain -- Weird Symptoms
Old Feb 12, 2015 | 06:24 PM
  #21
rmorin87's Avatar
Default ?
Originally Posted by z33_b6
awesome thanks for verifying this... im going to pick up a new cable and try this out... definitely worth a try... might even check the resistance on the old cable to see if i can see any symptoms. will change it regardless of what i see though
plan was to tackle the timing belt this long weekend but looks like ill be chasing this electrical issue for a good part of tomorrow/saturday
Did you end up replacing the battery cable and did it fix the problem? I'm having the same exact problem...
Old Feb 16, 2015 | 09:52 AM
  #22
lyleswk's Avatar
Probably not going to get a response from the OP. But, I had a similar situation that turned out to be a short in the radio. Decided the location of the cup holder combined with a cassette type ipod adapter that was not inserted is a bad combination after spilling some water from an open cup that hit the cassette and went into the radio. Battery drain started a couple days later. I diagnosed by removing one fuse at a time from non critical electrical components.
Old Dec 27, 2020 | 12:21 PM
  #23
Reed Cole Williamson's Avatar
Default Audi a4 cabriolet 2003
Hi i have had this issue this week before breaking up for christmas i had a new battery as have been moticing battwry drain the day after the battery was replaced with new i was driving and had the battery and abs lights flashing at me qhile driving then going off again every so often i have been able to jump the car and still drive it but i have been told possible auxillary belt tensioner but the belt is going fine not had chance to test anything but wondering if anyonw can help as now when i lock the car it beeps probably becaus of the low battery but what possibilities could this be other that the alternator or tensioner
Old Jun 13, 2021 | 03:15 PM
  #24
alenalien's Avatar
took it to a shop and they told me the battery Speed Test cable was bad....they replaced it and I also bought a new battery all problem went away....that was two years ago.
drb9
Dec 27, 2021 02:57 PM
ek4__
Oct 20, 2018 04:10 PM
2005audiA6
Dec 22, 2015 01:55 PM
wobblewoo
Mar 26, 2013 05:27 AM
gazza01
Jan 5, 2013 10:41 PM
