blow off valve buy?
....dont do it. If you're going for a BOV go with HKS or GREDDY. Just remember to buy the recirculation kit. I believe Neuspeed still sells them.
Ebay's a good spot for body parts and interior parts... but don't trust non of those knock off mechanic parts they sell.
If your car isn't even chipped yet why would you want to. Your only pushing about 8-9 psi stock. I see your already looking at a FMIC as well, why? Have you upgraded to a Big-Turbo? Your stock smic is sufficient for even the KO4 turbo (which is pointless upgrade for our cars because we have a KO3s turbos which is basically a hybrid. KO3 housing with KO4 guts. Settle down a little bit and take your time with your mods don't start turning your car into the E-Bay $5.00 and under dream machine. Factory upgrade to the 710 DV after you chip it, that would be plenty capable of handling the extra boost from chipping. All the parts you should look into have been discussed thoroughly many times in previous threads here at AF. Search the threads. Also check out www.a4mods.com. www.audizine.com. www.audigeeks.com. www.vwvortex.com and the www.audiforumsca.com (canadian audi forums. alot of good info from our brothers to the north) Good luck man don't rush it or you will not get the results you think you will and end up spending double if not more redoing stuff.
funkymillah
Dec 3, 2007 03:20 PM
jamma
Jun 25, 2006 12:46 AM
