Brake light sticking...
Old May 7, 2008 | 09:22 AM
Remman's Avatar
Default Brake light sticking...
Search didn't turn up with much. For the past week or so, people have been saying my brake light has been on when the car is parked. Last night, I saw it for the first time, after the car had been parked for several hours. I tapped the brake and it went off.
Any ideas of why this is doing that? Solutions? Doesn't seem like a hard problem to fix.
Old May 8, 2008 | 05:23 PM
Remman's Avatar
Default RE: Brake light sticking...
Mechanic sais it might be the brake light switch. Anyone ever heard of this and know how to change it?
Old May 8, 2008 | 06:07 PM
jonsaudi's Avatar
I had the same problem mos ago. Check this out...https://www.audiforums.com/m_686919/.../tm.htm#686919
Old May 9, 2008 | 11:57 AM
Remman's Avatar
Thanks for the link. How easy is it? I looked behind the pedal the best I could and couldn't see much. It looks like there isa plastic panel I need to remove to see more.
Old May 10, 2008 | 03:40 PM
PandaXpress's Avatar
oh dear god the brake light switch is a pain to get in to
u have to remove the panel and crawl in theres
and its a tight spot
Old Jun 3, 2008 | 11:04 AM
Partsman's Avatar
Its Def the brake light switch, very easy to change.
1: Pop the side panel of the dash off(where the fuse board is) with a flat head screwdriver.
2: There are two bolts here holdong the bottom section of the dash up...Take these out.
3: Now take out the two bolts in the bottom panel down near the steering wheel....the panel just pops out now.
4: There should be two switches one for the clutch and one for the brake..Just follow the brake pedal to see which one is which.
5:Twist out the old one and disconnect.
6: Now push the new one in and twist it...dont move the brake pedal while doing this...you must hear two clicks...this is the switch setting itself.
7:now recconect the switch and put all the panels back.
8: when your putting the panels back make sure to pop the diagnostic port back into the panel it usually falls out without noticing.
Old Sep 29, 2008 | 12:58 PM
adrianc's Avatar
Hi All
I have the same problem and my Cruise Control is not working at all.
I have been told that the Brake light sensor causes this.
Is it true that after the Brake Light switch is changed, the VAG-Com needs to reset the Cruise Control system, as it was locked when the faulty switch was detected?
Regards
Adrian Compton
Miguel1
Mar 19, 2015 05:08 AM
rabbitjetta
Nov 25, 2012 10:09 PM
oooo2002
Feb 15, 2010 01:30 AM
CumminsPilot
Apr 5, 2007 10:32 PM
ZedEx
Dec 19, 2005 10:30 PM
