Buying Used - A couple questions..
Old May 15, 2011 | 05:59 PM
AlanB-'s Avatar
Default Buying Used - A couple questions..
I'm considering buying a 05-07 Audi A4 - Many of the cars I've seen have high mileage (I really prefer a manual transmission and none in my area have low mileage), generally ranging from 70,000-85,000
What would be some problems with buying a 2.0T with this type of mileage? What are some typical problems/issues and what needs to be replaced around this time?
Thank you in advance for your replies.
Old May 16, 2011 | 07:50 AM
olstyn's Avatar
That would be a B7 A4, not a B6. I'd try asking over in the B7 forum, as the responses you get *should* be more useful.
If the 2.0T is anything like the 1.8T, you'll be looking at cars that either just had or will shortly need a timing belt change - find out what the (real world) interval is for the 2.0T and check whether it's been done on any car you're interested in buying. It's a big issue for 1.8T cars because the manual says 105K, but in reality-land, it needs to be done between 70K and 80K, and it can cost $1K (more, in some areas) to get it done. Basically, if the interval on the 2.0T is similar, use it as a negotiation point. If it hasn't been done, you can ask for a significant amount of money off the asking price based on that need, and if it has been done, you've got peace of mind. Either way, it's best to know what you're getting into.
kopez03
Nov 16, 2011 08:44 PM
JasonA4
B7 Models
Nov 13, 2011 06:31 PM
audi1031
Jan 17, 2010 02:14 PM
nadler
Aug 10, 2007 12:59 AM
2000S4
Nov 28, 2006 05:54 PM
