Camber Kit
Old Nov 1, 2009 | 08:04 PM
Audie's Audi's Avatar
Default Camber Kit
Looking for good camber kit for my car.
any suggestions?
thanks,
Audra
Old Nov 3, 2009 | 08:28 AM
Mike-2ptzero's Avatar
I offer the Stern Front adjustable upper control arms for $579.95 shipped in the USA. If you need something for the rears let me know. This is pretty much the only way to deal with camber issues on the Audi B5/B6/B7.
Old Nov 3, 2009 | 11:32 AM
pa4ul's Avatar
just outta curisoty why u need a chamber kit for u gettin sum rims and a drop.?
Old Nov 3, 2009 | 03:47 PM
Had new tires put on last Friday, the tires I had previously were losing massive amounts of air pressure, but there were no holes or anything in them and they still had half of their tread left. So on my alignment one of the numbers came out to be like 1.34 or something (I'll post the actual number later) when it should be at .91 at most....
Was told I needed a Camber Kit to fit it. Can't remember if it's front or rear, I'll get back on that.
Old Nov 4, 2009 | 11:17 AM
pa4ul's Avatar
u have stock rims right. Where the tires that were losing air pressure the pirrellis>?
Old Nov 7, 2009 | 05:42 PM
the rims are stock yes, they are the rs4 rims. not sure what tires they were, I'll have to check my spare and get back to you on that. I'm running Potenza RE960's now, on the same rims... had the rims cleaned and inspected (my dad is the GM at the shop so nothing was left out), they found nothing wrong so I'll have them til spring when I can afford new ones.
the alignment on my front right camber was -1.34 when it should be between -0.92 and -0.08... so it's way off. I should get both cambers done for the front since the left camber was -1.01.
Any ideas?
Old Mar 5, 2011 | 01:06 AM
A4UltraSport's Avatar
Any ideas?
I just recently experienced trouble with my A4Quattro's alignment on my driver's side front and it's around 1.63. I have 18 inch Audi stock wheels and no suspension mods. I was wondering what you did to fix your problem. I have considered purchasing the KMAC camber kit, but was wondering if this was overkill for my problem.
DEjunkie
Jun 8, 2008 10:06 AM
theTTkid
May 25, 2008 02:47 PM
mypreludeisred
Jun 24, 2006 05:04 AM
lyl
May 3, 2006 04:45 PM
japchef
Oct 22, 2004 03:52 AM
