Camber Kit
I offer the Stern Front adjustable upper control arms for $579.95 shipped in the USA. If you need something for the rears let me know. This is pretty much the only way to deal with camber issues on the Audi B5/B6/B7.
Had new tires put on last Friday, the tires I had previously were losing massive amounts of air pressure, but there were no holes or anything in them and they still had half of their tread left. So on my alignment one of the numbers came out to be like 1.34 or something (I'll post the actual number later) when it should be at .91 at most....
Was told I needed a Camber Kit to fit it. Can't remember if it's front or rear, I'll get back on that.
the rims are stock yes, they are the rs4 rims. not sure what tires they were, I'll have to check my spare and get back to you on that. I'm running Potenza RE960's now, on the same rims... had the rims cleaned and inspected (my dad is the GM at the shop so nothing was left out), they found nothing wrong so I'll have them til spring when I can afford new ones.
the alignment on my front right camber was -1.34 when it should be between -0.92 and -0.08... so it's way off. I should get both cambers done for the front since the left camber was -1.01.
Any ideas?
Any ideas?
Any ideas?
Any ideas?
I just recently experienced trouble with my A4Quattro's alignment on my driver's side front and it's around 1.63. I have 18 inch Audi stock wheels and no suspension mods. I was wondering what you did to fix your problem. I have considered purchasing the KMAC camber kit, but was wondering if this was overkill for my problem.
