Cant resync keyfob (1 key)
Old Sep 29, 2012 | 06:09 PM
adamellisuk's Avatar
Default Cant resync keyfob (1 key)
I removed the battery and the keyfob to do a DIY carbon fibre wrap around the key today. When i put it back together it would not work on my car (2004 a4 b6). Normally when taking the keyfob appart i would just put the key in the car ignition and play about with it and it would work again. This time though i have had no luck. I replaced the battery just incase but still no joy.
Pressing the open car button and then putting the key in the driver side door, turning it left and then right, does not work.
Inserting the key into the ignition and setting it into the on position then pressing the open button, or pressing the open and close button, does not work.
Inserting the key into the ignition and starting the car then turning it off 4 times, does not work.
I have tried loads but nothing seems to work. I have only 1 key also so some of the reset instructions are no good. Can anyone else suggest anything?
Cheers guys
Old Sep 29, 2012 | 06:38 PM
''''I wonder if the wrap is interfering with the signal frequency?'''
Anyone know where the signal freq would come from on the key?
'Press open, turn ignition on, then off, press open and pull the key out and press open again. ''
This does not work either.
budnfrida
May 28, 2012 10:49 PM
JohnnySack
Dec 15, 2010 09:00 AM
Bklynrx7
Apr 7, 2009 08:51 PM
kriptonik
Mar 5, 2007 04:09 AM
