car heat issue
Old Feb 24, 2012 | 07:28 PM
jamezz23's Avatar
Default car heat issue
The car doesn't put out hot air when idling. Heater core was flushed but not sure if they bled the lines for air. It isn't low on coolant, you don't even have to be driving to make heat come out, just rev it up to around 2k rpm's and heat will begin to come out. I see one visible bleeder at least I think it is its one, above the intake manifold on the hard pipe. I also read that there is another bleeder on the heater core. I was wondering if the bleeder above the intake manifold would get all the air out by itself or would I have to find the bleeder on the heater core? And to bleed it should the car be up to temp and running when you loosen the bleeder? I am a novice at mechinacal work but I pick up on things pretty fast if anyone has some advice. The car is a 02 1.8t
Old Feb 24, 2012 | 07:57 PM
jamezz23's Avatar
omg a triple post? sorry that's what I get for using a cell phone :/ it was giving me errors so I just pressed the back button and resubmitted it not knowing that it posted it every time.
Old Jan 9, 2019 | 11:00 AM
randyladwig's Avatar
After doing a CLR flush and trying to bleed my heater core, I found poor flow from the engine. Used the garden hose to 3/4 inch adapters I had to connect to the heater hoses and back-flushed the engine. Flow significantly improved. Heat working much better.
Johnskisalot
Apr 3, 2014 02:40 PM
jamezz23
Feb 29, 2012 06:04 PM
jamezz23
Feb 24, 2012 07:24 PM
kingming
Nov 21, 2005 12:45 AM
