No heat
Have you done anything recently on the car? Changed coolant, or filled it up?
Could be air in the heater core or blocked neater core.
Check the hoses in the engine compartment going to and from the heater core at the firewall.
I fludhed out the heater core and i am getting flow in eiter direction. I used the outlet hose to bleed the system and i did not seem to have any air. I am thinking the t-sata may be stuck open but then when the car gets hot i should have heat all of the time.. I dont know....
