Car jerks after ECU was flashed to the performance program
Old Feb 22, 2008 | 10:19 PM
dgfirefighter86's Avatar
Default Car jerks after ECU was flashed to the performance program
I recently had the ECU flashed to the performance mode on my 2003 Audi A4 1.8T. While driving at about 45pmh and i let off the gas, the rpm's drop to 2000, i hit the gas again so i speed up again, the car jerks like its jumping into another gear. i didnt see any codes while using VAG-COM. Is there anyone that is having this problem or has an idea to what the problem could be. 2003
audi A4 1.8T
42,000 miles
GIAC Flashloader Performance & Stock Programs.
Old Feb 23, 2008 | 01:45 AM
Kyle09's Avatar
Default RE: Car jerks after ECU was flashed to the performance program
It sounds like its just the extra power...my car jerked like a mother when I was stage 1+..Then when I went stage 3 I could break peoples necks
Old Feb 23, 2008 | 03:29 AM
audiprotein's Avatar
I was about to say CoilPack but then saw that you Vaged that.
Old Feb 23, 2008 | 10:45 AM
I brought the car back to the place i got it flashed and they ran vag-com and there were no codes that were before or after the flash.
Old Feb 23, 2008 | 01:02 PM
IMHO, Ive heard sometimes Flashed ECU's do that, thats why it is recommended to like have a break in period for a bout 100 miles (dont rev yourcar to often and dont drive it hard) so Flash gets "in a contact with" your ECU ))
Might be your plugs too, cause now u have more stress on your engine.
Check out here, AMZE had some problems with his ECU whe he got Flashed.
https://www.audiforums.com/m_784397/tm.htm
Old Feb 23, 2008 | 04:31 PM
What are some good plugs and where can i get them at??
Old Feb 23, 2008 | 08:41 PM
You can get plugs anywhere from Walmart to some Crazy Website ))
Search on forums, you will find some good info.
Old Feb 24, 2008 | 06:59 AM
what is the gap on the spark plugs??
Old Feb 24, 2008 | 12:33 PM
I think it is 0.28, i've heard that "The nominal range for the 1.8t is .028-.032 but that differs for some plugs and setups."
By the way, ifu search on forums u will find a lot of useful info
Old Feb 24, 2008 | 12:42 PM
thanks man
ethic
Dec 24, 2012 12:37 AM
wpv123
Jul 21, 2007 08:29 AM
fumoazul99
Jun 28, 2007 05:39 PM
PandaXpress
Apr 5, 2007 02:10 PM
Jacek
Nov 23, 2004 01:32 PM
