Car studders issue
Old 06-23-2008, 06:32 PM
aznmpr's Avatar
Default Car studders issue
2004 1.8t quattro 6speed
During the weekend i changed my engine oil and spark plugs (Denso Irdium) i have notice during today while i was driving that when i push it right over 3k rpm that my car jerks and my rpm become rough. But this only occurs only if i push it and goes over 3k rpm.. any clues?
Also i need to recharge my AC i notice there are 2 pipes one small and one big on top that goes into the passenger side... and the little pipe has a black cover over it... is that where i would recharge it at?
Old 06-23-2008, 07:17 PM
auditech79's Avatar
Default RE: Car studders issue
Check the fault codes, more than likely it will have a miss-fire on one of the cylinders. Then take out the spark plug again and make sure there is nothing wrong with it, if its ok, then its the coil for that cylinder.
Old 06-23-2008, 07:48 PM
audiprotein's Avatar
Maybe you didnt gap them the right way.
Old 06-23-2008, 08:57 PM
aznmpr's Avatar
how do i gap them??? i bought them from ecstuning and i thought it would of just been a plug and play.... also i never used any anti seize compound or anything on them, they are just put in raw... is that wrong?
Old 06-23-2008, 09:45 PM
It depends on a spark plug and setup u got. If u are pretty much stock, id say go with 0.28 -thats the most common gap.
Old 06-23-2008, 09:50 PM
Man, i was trying to type and put some pics but it doesn go thru. Second pic from top is the Gapper
http://a4mods.com/index.php?page=web...pperplugs.html
Old 06-23-2008, 10:08 PM
aznmpr's Avatar
hmmm the pre gap is 0.4mm on the spark.. but i will try to pre gap it lucky i saved one of the old ones... thanks
about the AC is it the two pipe going on the top going into the passenger side?
Old 06-23-2008, 10:27 PM
Usually, the gap on old spark plugs is way more than 0.28, so it wouldnt really help measuring it, but who knows.
This might help you
nelson0639
12-08-2014 04:44 PM
hotswaps
08-08-2013 05:50 PM
hotswaps
05-27-2013 07:02 PM
Dallas09
02-14-2009 05:08 PM
fobyulous
03-27-2007 01:59 AM
Quick Reply: Car studders issue
