changing spark plugs
Old Mar 30, 2008 | 10:51 AM
zboy7's Avatar
Default changing spark plugs
How do I remove the spark plugs from a 2003 audi a4, i cannot for the life of me figure out how to get the cap off.... i found the plugs, they are on the block but i cant get the black cap off..
Old Mar 30, 2008 | 11:31 AM
captain's Avatar
Default RE: changing spark plugs
Those are coil packs not caps, they pull straight out and are about 8 inches long. Push in on the connector as you push down on the release tab, then pull out the connector. Pull the coil pack straight out. You will need a long extension secured to the socket somehow, I jammed some duct tape in there, otherwise you will be trying to figure out how to get the socket out.
Old Mar 30, 2008 | 11:51 AM
techbod's Avatar
4-cyl. 1.8 ltr. 5-valve turbocharged engines – Remove engine cover panel . – Switch off ignition. – Detach connectors -1- from ignition coils. – Push connector -1- towards pencil-type ignition coil, press catch down by hand and pull off connector. – Use puller -T40039- to detach pencil-type ignition coils from spark plugs. – Remove spark plugs using spark plug socket -T40039-. – Install new spark plugs.
[IMG]local://upfiles/12092/96299FF0BCC047A8B91F949DC6C1132A.jpg[/IMG]
Old Mar 30, 2008 | 01:56 PM
mattsaudi90's Avatar
It is really easy, takes about 2 minutes.
Just get an actual spark plug socket with a magnet, or rubber securing ring.
Old Mar 30, 2008 | 05:10 PM
SrK's Avatar
SrK
Not to change the subject but when are the spark plugs and ignition coils are suggested to be changed?
I am at 105K miles on my B6 and I once had a problem with the start up. it took 3 trys to start it...
Any place to get the ignition coils for a good price?
Thanks
Old Mar 30, 2008 | 05:12 PM
SrK's Avatar
SrK
forgot to submit...
Old Mar 30, 2008 | 06:36 PM
SRK,
The A4/1.8t coils are very problematic. They go off all the time. Many owners keep spares lol. Time to replace them, and I would reccomend www.ecstuning.com and get the latest Hitachi revision.
Old Mar 30, 2008 | 08:00 PM
SrK's Avatar
SrK
Thanks Matt,
Looks like its time to spend some more money...
Old Mar 30, 2008 | 08:18 PM
Not a problem SRK. Yep, best to get them out of the way now, and not get left with a car that stutters, and has no power.
I have experienced the bad coil thing first hand... You replace one, one more goes, one more.... Until they are all replaced. It is a very odd thing lol.
Old Mar 31, 2008 | 11:35 AM
acollicott's Avatar
ORIGINAL: mattsaudi90
I keep a set of four in my trunk
jlight113
May 4, 2010 10:44 PM
Snapperanton
Jan 26, 2010 04:29 PM
dpatt420
Jun 26, 2008 09:32 PM
snogoer
Aug 28, 2005 06:39 PM
Marek
Mar 16, 2005 01:54 PM
