Clear corner mod
Old May 13, 2008 | 05:27 PM
a4nate3.0's Avatar
Member
Default Clear corner mod
Well I was going to make an attempt at the clear corner mod. And like with all projects there is always the major snag.I could not get the lower torx screws off. I W-D'ed the crap out of them, and they won't budge. So I threw in the towel. Any suggestions? Sawz-all, sledge hammer?
Old May 13, 2008 | 07:12 PM
cclazer's Avatar
Member
Default RE: Clear corner mod
If they're to tight for you, I'd suggest a long-enough torxdriver that you can use pliers(or whatever you got) to grab the end of the driver and break them loose.This will usually give you enough leverage to loosen tougher screws. It really shouldn't take any more effort than that...
Old May 13, 2008 | 08:45 PM
grpape's Avatar
Spray it with some PB Blaster and let it sit overnight. It's amazing what this stuff will break loose.
Old May 14, 2008 | 12:34 PM
harryd14's Avatar
if that does work for your clear corner mod, please post some pics as to how it looks and how easy or difficult the procedure was to do
audisnut
Mar 13, 2008 04:13 PM
a88fl1
Feb 25, 2008 04:25 PM
Ldetter
Jan 17, 2008 06:31 PM
widlcats
Jan 9, 2008 08:25 PM
thepirate
Oct 16, 2006 02:48 AM
