Clicking (relay) noise under LOAD - Tick Tick Tick
Old Feb 21, 2008 | 09:00 PM
mz3bo's Avatar
Default Clicking (relay) noise under LOAD - Tick Tick Tick
Hi,
Car is a 2004 A4 Wagon 1.8t automatic quattro. When I accelerate, there is a clicking noise coming from under the dash on the driver side somewhere. It will not "tick tick tick" when I rev the car at Park or in Neutral. The click noise is heard only when I press the gaz pedal, as soon as I release, no more "click click click..."
Everything is working A1, no hesitation, no faulty electronix etc...
Anyone has an idea ?
Thanks
Old Feb 22, 2008 | 07:17 PM
mz3bo's Avatar
Default RE: Clicking (relay) noise under LOAD - Tick Tick Tick
Hi,
The noise is coming from the inside. I notice something today, WHILE I am acceleratin (pressing the pedal), if I touch the brake pedal, just a very very very light pressure, it will stop the clicking sound... If I press to hard, the Ecu will cut the power out.
Thanks
Old Feb 23, 2008 | 01:36 PM
Kyle09's Avatar
I would go to advanced auto parts/oriley auto parts/auto zone and have then scan for codes.
Old Feb 23, 2008 | 02:15 PM
mz3bo's Avatar
There are not check engine codes or anything like that...
Old Jul 11, 2008 | 01:56 PM
sophik's Avatar
Has anyone figured out the cause/solution to this. Happening to my 2002 a4 and audi tech has no clue what it is
Old Jul 4, 2010 | 04:53 PM
ColoradoAudiDriver's Avatar
Hi--This thread started a couple years back but I'm revisiting since I'm getting a similar problem. No other warning lights, just an annoying "clicking" sound coming from beneath the dash. It sounds similar to an electrical solenoid click--so I'm guessing it's an electrical issue. It doesn't seem to affect performance, but it's definitely related to pressure on the gas pedal and the sound becomes more frequent with slight pedal changes. Anyone else come across this and/or have a fix? Thanks in advance.
Old Jul 5, 2010 | 11:25 AM
Dan1969's Avatar
So what you can do check all the electronics work, radio, wipers, washer bottle, lights, blinker, hazards, fogs, cigarrette lighter, sunroor, windows... Something like that could be either the dashboard or the steering wheel controller.
Another more radical way of troubleshooting is to take the fuses out one by one to see if the noise stops at one point, but be carefull as one of the fuses might cause a diferent failure.
Old Jul 5, 2010 | 12:43 PM
Thanks. What a pain but I'll give it a try.
Old Jun 3, 2011 | 12:41 PM
HerrSchnell's Avatar
Default Any Success?
Have you found the source of the ticking? I'm having (been having) the same issue. It's difficult to troubleshoot as it only occurs under acceleration.
Old Jun 9, 2011 | 03:28 PM
sburkeatqmi's Avatar
I have the same "ticking" sound but it goes away after a few miles.
