cold air intake problem :( HELP
The "read between the lines" of that code, in this instance, should be:
"Take that intake off and put the stock one back on. You were suckered."
Not only does that intake do nothing for you, it should've had nothing to do with an underboost. It isn't connecting to anything on the pressure side, and there should've been no reason to disconnect anything on the pressure side.
Sp33d07
Sep 3, 2006 05:06 AM
